I can't believe this thread is still going!! Well, here's the update. I granaded my 35 at a dyno event at JandH Performance in Redding, CA (thanks to Joel for the loaner 35 to get me home, you guys are awesome!). So, I did what I should have done in the first place, call Pius Erbelle at Bell Turbo in Stockton, CA and begged him to build me a USB before he moves his shop. The result: 50 hp gain overnight, no other mods. I'm at 400 hp easy and loving it. The turbo really spools quick and hard, right to 45lb and the temps were only at 1400+ for the last two seconds of the dyno run. I'm going to pipe in a HT3B for a twin setup at 70lbs boost or so, after I stud the head of course. I got a custom plate from Piers (along with the cam and ringed head), so I have alot to do before May madness. I'll tell ya though, that USB is great all on it's own. I pulled my 10k # camper back from Piers' shop up and down the passes in WA, OR and CA and was able to do 70mph up all but two and never at more that 1200deg, which I'm more than comfortable with. A little surge if you try and shift while it's pumping out 20+ lbs of boost, but I just learned to back off the trottle ever so slightly before pushing the clutch, wallah, no surge. It's a beast, pricey, but a beast.
