Competition Hx 50
Competition How do u get 500hp out ofa 12Valve?
Competition EGT Spread
Funny how the obscure turbo questions always pop up when there is one on ebay. :-laf
If you are speaking of an off the shelf HX50 then its probably got somewhere around a 64mm inducer and a pretty large turbine housing.
They will usually make boost into the 50 range... (boom)
As far as where your going to be truck pulling at, it would have been a good turbo about 5 years ago but these days it wont cut it.
Not to sound like a broken record or anything but the best off the shelf 2. 8 bolt on charger you can get is an Aurora 5000 from ATS.
There are some other choices out there also like the GT4294 or GT42102 but they will require an adapter or large mouth manifold and some other small mods to work.
HX50's are available in several different flavors I thought there was on close to 70mm inducer, I think you might have been able to get one with a 19cm or so turbine housing, but most were quite a bit bigger, but as the broken record mentioned, 5 years ago they were a hot ticket, but have been surpassed in reliability and performance.
As Dan mentioned above the truck pulling charger world is constantly evolving. Dan learned this the hard way last year:-laf :{
Yeah Justin,
You caught me on the ebay thing. :-laf Just curious. I know you don't get something for nothing, but I think the seller also had some cool fuzzy dice to go with it. :D
Off topic my question is how many people are in Justins fleet of web surfers. If it is on the internet he seems to find it!!
