Did a search on limits of the stock turbo and did not find much.
I understand 35psi is max for "cool boost"
what HP is the supposed limit. I expect to rarely be at max, but want to know what to expect. I have a comp (tapped) clutch holds fine (checking out the sbc ofe. )
Should I worry about overboost or temperature to know the limits of the turbo. I will eventually want to switch to something that spools quick as I tow a lot (8k lbs)
hoping I can run the comp in EZ mode and the injectors and be fine, then turn on the box and go easy with it when empty.
any suggestions? what about the HTTurbo stage II or III for a hybrid?
