HX35 Turbo Question
Boost Module on Stock Truck
rear speakers
Ok guys I need some help with an ID for this turbo. It is a HX35W with a part #3534919, I think it is originally from a 95-96 CTD. Wanting to find out if this is correct year, also what size exhaust housing it came with. Would this be a good upgrade turbo (as far as HX35 goes) for a HY equipped Ram?
Any help is appreciated.....
Doug S.
Doug, I'm not sure what the ex. housing is on the HX you have, but, if it's a stock housing off a 96 it's a 12cm. A HX35 with a 12 would be a great set up for you 24 valve. My good friend Blackdog ran a 35 and a 12 with a set of big injectors and a JVD box for a while hitting over 50 psi of boost and it lasted until we went to the race track... . Be Good!!
1994 2500 Regular Cab Longbed, 4x4 Red & Silver, Stainless Steel Rocker Panels, 2. 5" Skyjacker, tweaked afc & pump, BIG plate, HX35 w/16cm housing,no muffler or resonator, 16. 5x9. 75 Weld Rims, 33x12. 50 BFG Mud Terrians, 60 psi boost gauge, pryometer, J&J Stainless Steel rear 10" drop bumper w/backup lights, Westin pushbar, PIAA 90 Pro series lights, Weatherguard toolbox 27", Aluminum bed rails & tailgate protector, President Lincoln H. A. M. radio converted, 400 watt linear, Premier Pioneer stereo, *COMING SOON* 370 hp injectors,
