Details here: TDR Privileges
Yes, it is a direct replacement if you use your 14cm non gated housing. Just plug the boost actuator port on the compressor housing.
If you want to use the 12cm gated housing they come with then you will have to shorten the down-pipe 1-1/4" due to the extra length of the gated housing.
