HX35 wastegated housings available?
Towing Twins Which Chargers/housings
B&M drain plug
What housing sizes are available that are wastegated? and what applications are these housings avaialable on.
are these wastegates any good or would you be better using a non wastegated housing and an external wastegate.
How do you adjust the wastegates on these chargers.
Thanks for any and all help
Travis
12cm and 14cm
12cm came on stock trucks... 14cm came on some bigger motors w/ H1C's pretty hard to find used.
adjust the wastegate with a little bleed orifice ("boost elbow")
what's the rest of your combo? you should be fine w/ the integral gate... when it becomes a restriction, I'd just go w/ a different turbo.
Forrest
