hx40 question
bg users beware
installed the Carter P4601HP pump ...
For all you guys running the hx40 can you tell me the model # you have? I am trying to do some research but need exact #'s.....
Also did your turbo require anything other than being clocked to bolt up (besides a downpipe)? If so what else was needed/involved?
Thanks,
Doug S.
HX40w--is all I can tell ya on that end and it should come with the gaskets you need, but you may need some 3/8" bolts and nuts(I think that's the size to bolt it back onto the manifold & the downpipe you know of-hope this helps----chris
Jet... you'll need the 4" band clamp to connect it to your downpipe. Also, the stock HX-40 has the wastegate actuator setup differently than the HX-35s in the Dodge trucks. You should have the actuator assembly changed. Mine wasn't and I made it work by turning the actuator assembly head 180 degrees and rerouting my heater line. It's still very close to the exhaust manifold but it works. By the way, I love my 40. Good luck.
98. 5 2500, 24v, 5 speed, QC, 4x4, 4. 10 LSD, short bed, Line-X liner, tow package, camper suspension, Westin nerfs, camper shell, TST PowerMax Competition, 275 RVs, Psychotty air, HX-40, 4" straight pipe exhaust, ProComp A/T 305/70/R16s, EGT/Boost pillar gauges, Grover air horns... Love my Cummins, no love for Dodge
what is an HX-40????
99 quad cab 4x4 5spd 355 gears sandstone color K&N air filter starit pipe spray in bed liner goose neck ball- theres nothig like the smell of Diesel in the morning.
Hoss:
An HX-40 is a Holset Turbocharger which
is put on the 8. 3 Cummins Diesel Engine.
It flows alot more air than our HX-35's
and that is why when H. P. gets above
about 350 some of the members end up
going to it. At those H. P. ratings the
HX-35 is supposedly "off it's efficiency
area" and I believe it because my truck
is suffering right now too. I also hope to
have one soon.
Hope this has helped you!
John_P
Red '96 4x4 2500 Auto 3. 54, TST #5, Major Pump Mods(By "Scheid Diesel") 370 Diamond B Injectors, Gov. Spring kit, AFC Spring kit, Banks Exhaust, Prime Loc, Cummins Chrome Kit,Psychotty Air Filter, Pro-Torque Converter, BD Valve Body, BD Pressure Loc, Isspro Gauges, Sendel 16" Alum Wheels w/ 33" BFGs
Where are you guys finding the part numbers on your HX-40s? I just looked all over mine and couldn't find any 359- part numbers, they all started with 353.
BTW, I didn't get to install mine today because of the **** weather. I'll have to just see how bad EGTs are with the stock turbo pulling the Sunol Grade. Oh well. Monday.
Rob
2001. 5 RAM 3500 QC 4x4 ETH/DEE Silver/Agate, 4. 10, USGear OD, Rickson 19. 5 Wheels, DD EZ, DD3 Injectors, HX-40, Southbend Clutch, SPA Guages, Psychotty, Firestone Airbags, Hellwig Rear Swaybar, Torklift Superhitch & Camper Tiedowns, Mag-Hytec Diff Cover, DD 4" Exhaust, US Gear Exhaust Brake, etc.
Originally posted by WeirCummin:
Doug,
Mine is a #3591019.
csutton7 has a 3591018 which is the preferred turbo to use.
Dean
Can you please tell us what the difference is between the two ?
John
2K Auto, 354 gears, VA and BLUE box, 4" exhaust, Auto Meter EGT and 60# Boost Guage, pressure lock,(soon to be replaced by DTT VB and TC) every option but the sliding rear window and snow plow prep. and sport package
supposed to be the truth--with the increased demand and then the rash of recent failures they've increased the price to cover their butts----that's what I've heard more than once---chris
[This message has been edited by csutton7 (edited 04-22-2001). ]
I stopped into the Utah distributer for Holset (High Tech Turbo) a couple of weeks ago. I was told that a month ago about half the HX40 models prices were almost doubled. the rest remain either unchanged or had a very little increase.
High Tech is a small company with a vast amount of talent (over 15 years in business). They recommend a hybred HX35 over the HX40 for out trucks, which is also a lot cheaper way to go. They've never advertised in the TDR because they felt the rates were prohibative. They've got very competative priceing though.
