HY35 Turbo limitations??
2002 Dodge Ram
Brakes (lack there of) $#!+
What are the pro's/con's of the stock HY35 turbo when the other mods on an 01 auto would be Bill K. TC/VB, EZ, DD Stage 1's, RE-0880 and full 4" exhaust?
Is the "puny" 9cm turbo limiting the full power potential of these mods? If so, in what way?
Is there some risk for mechanical damage of any type by not having a larger turbo?
Thanks...
White 2001. 5 2500 ST, SWB, 4X4,QC, AUTO, 4. 10's, LSD, 285/75/16 On Weld Outbacks, PIAA 510's, Line-x, Tinted glass, Redline 85+.
Soon to come: Bill K's TC/VB, EZ, DD Stage 1, DiPricol Gauges, RE-0880 and 25-0880, Stan's Headers 4" exhaust, Bilstein shocks, Westin step-bars.
pro is faster spool up , major con is limited mount of boost you will attain , i have heard 32psi max by disabling wastegate , on my hx35 i have seen as much as 46psi , though the hx is out of its efficency map above 39psi . i am running around right now with 34 and i can feel the hp decrease in my seat o' the pants meter .
Hey Joe, glad to see you are a full blooded TDR member and able to post #ad
Tom
Tom Golden
Godzilla: Patriot Blue 2001 2500 SLT QC 4X4 LWB ETH/DEE, Tow & Camper packages, 3. 54 Ltd. Slip, 4 wheel disc ABS, Isspro EGT/boost gauges, black SmittyBilt nerf bars, K&N RE-0880 & pre-filter, no silencer ring, TDR decal, Jack holiday antenna ball
NRA Life/CRPA/El Dorado #26 F. &A. M. of California
Thanks, Tom. I posted "Hello and Thanks" yesterday to give you and some other's a thank you for the private email responses while I was still lurking. Joe
Kinda curious !,
How can the HX35 be out of its "efficency map", if it's boosting 46 PSI?,
seems like it's still workin'.....
2001 Quad,4x4,4. 10LS,LB,Loaded,stock,... . 65 Chevelle sedan, Hella nice driver, 53 Nash Rambler Convt,1 of 653 built,[not a Metro], GM drivetrain, injection, and auto/od
Specialized FSR PRO Stumpjumper Cannondale F2000, Loaded
MTD Lawn tractor with flames
12' fishin' boat, loaded. .
Maybe this will help a lil, think of how fast that HX35 has to spin to produce 46psi. Thats the advantage of an HX40 it has a bigger compressor therefore produces more air, less RPM. Thats what they mean when they say "effciency range".
I have had my punny HY to 39-40 psi of boost. I have read that the efficiency limit on the HY is at 32. The HY spools up fast, but does not move the volume of air a bomber needs. There is an HX-40 in my future.
John D. Rathert Jr.
01 2500 Forrest Green Sport SLT+ QC LWB 4x4 Auto 3. 54 rear end with all options avail. DC Nerf Bars, DC Grill Gard, DC mud flaps, Line-X bed liner, Leer 160XL Topper, Power Edge, EZ Edge, SPA Boost/EGT Gauge on pillar mount, DDT's tc/vb combo, 275 RV injectors, DD 4" Exhaust and a KN RE0880 where the air box use to be. New turbo (HX40), SS fuel lines and bigger injectors in planning stages... . See My Truck, Dads truck: 98. 5 3500 SLT QC LWB 4x4, Brother Truck: 92 W250 SLT CC LWB 4x4 (Dads old truck) Winter fun - 2000 Skidoo Summit 700
Ah so... ... ...
It's the volume versus pressure thing... . #ad
2001 Quad,4x4,4. 10LS,LB,Loaded enough,stock,... . 65 Chevelle sedan, Hella nice driver, 53 Nash Rambler Convt,1 of 653 built,[not a Metro], GM drivetrain, injection, and auto/od
Stuff to consider would be the heat generated by the compressor wheel, the potential for surge which is like cavitation, drive pressure, egt's, boost level, efficiency level, compressor ratios, and CFM's. It's a science #ad
Nowel/Performance Diesel, currently running the H2E
[This message has been edited by HVAC (edited 02-27-2001). ]
HVAC... . I'm honored to have you responding in this post, but since you're here, could you please re-read my two questions and give a short response? I just don't understand the "turbo" thing, and if I do the mild bombs mentioned I just want to know that I will realize the full potential of whatever increased performance they should offer, and also not going to "hurt" my blessed cummins. thanks
The max I saw outta my HY35 was 44, but with BIG injectors and the JVD box. But that was runnin really high temps. Now my HX35 is pushin well over 50lbs, not sure how much b/c my Isspro is only a 50lbs guage. I know it's over it's limits. Just hope she gets me by for a little while longer till I figure out my next setup. Hope this helps. Good luck !!
  • 2001 Cummins, Black, QC, SWB, Agate Leather, Every Option Available
  • 3:55's, Auto, 4x4, 2. 5" Skyjacker, 33x12. 50 BFG Mudders on 16. 5x9. 75 Weld Super Singles
  • JVD Torque Enhancer, Big custom Injectors, Boost Module, HX35 w/12cm housing non-wastegated, High Stall Pro Torque Convertor, Performance Valve Body, Silencer Ring removed, K&N Air Filter
  • No Muffler, No Resonator, Isspro Boost/Pyrometer Guages mounted on A-pillar
  • Dee Zee Diamond Plate Toolbox, Bed Rails, Tailgate Protector, Chrome Rocker Panels, 4" Chrome Tip
  • Westin Chrome Push Bar, Brush Guards
  • White Face Guages
  • Cobra 29 Sound Tracker Night Watch CB
