hyd booster hook-up - need help
91 W250 LE for sale - in classifieds soon
Advice on 3.9 cummins!
4bt out of bread truck. I have 3 lines coming off the pump. Can someone tell me how to hook this up to hyd booster and power steering? One line appears to be high pressure, but the other two have hose clamps so must be low pressure (unless someone cut one). Came out of bread truck.
All the scratching of my head will not come up with a config for 1 HP and 2 LP. Now if it was 2 HP I could make that work - I think.
In case this info is needed - Chevy Blazer, 85 Blazer Diesel Hyd Booster, 78 Chevy pwer steering. PS has flare, Hyd Boost has O-ring, so I'll need to get something made. . Pump has flares.
Thanks,
Doug
I am doing a 83 chevy duelly conversion, The pressure line goes from the pump to the hydro boost then to the steering. The hydro has a return line and so does the steering box. The line to the hydro screwed right into the back of the dodge pump, On mine the steering box has o-ring lines and the dodge return line screw into steering box. All I will have to do is put a Y in to put the returns together.
thanks and thanks again since 'thanks' is too short!
I found the third port on the hydro. It was covered by tape then painted.
