Today I noticed the frame behind the front tire was wet. Upon further inspection I found brake fuild leaking from between the brake fluid reservior ( master cylinder ) and the hydraulic booster. I see about three bolts in the area of the leak and was wondering if there is a seal or o-ring between the two or does the whole thing need replaced? Does the reservior seperate from the hydraulic booster? My factory service manual is a little fuzzy on this. Any help is appreciated.
Thanks, Scott
Thanks, Scott
