Vaughn MacKenzie
A friend is having grief with his '99 quadcab 4x4. His PS/brake pump died, leaking oil on the ground, without warning. Truck only has 33,000 miles.
He's replaced it with 2 remans and neither one works out of the box. We tried bench mounting them and filling them with oil, hooking up the outlet hose and spinning it with a drill. Doesn't pump a drop.
Can someone with a service manual look up and see if there is some special priming or bleeding procedure when R&R-ing a hydraulic pump? Shouldn't they work on the bench tested as above?
He took apart the original and it was pretty filthy and gooked up with black residue. It would be a good idea to flush the system every 20-30,000 miles or once a year as a good preventive measure. I did that on my '01 and never had a lick of trouble in 87,000 miles. I used Valvoline semi synthetic.
Vaughn
Vaughn
