I'm no expert but there's only a few places it can be leaking from ,on mine it was coming from the seal for the input shaft (top of the steering box).
I had a friend turn the steering wheel to the stop to put pressure on it while looking for the leak( I was under the truck off to one side and had eye protection )and was able to see it flowing from the top side of the box at the shaft, other places to check would be hose connections and the I think they call it the pitman arm shaft (lower out put shaft)and if its none of those it check the power power steering pump you should be able to see by looking down from the area of the drivers side battery ,hope this helps,if it is the box
it took three before they found one that didn't have a problem out of the box,good luck
