I had a transmission cooler line fail this week on my '95 that left me stranded. The fitting failed- it was either compression or flared, haven't taken it apart yet. I bought goodyear push lock hydraulic hose to replace it. Has anyone else used the push lock or insta-lock hose and matching barbed fittings without clamps? The guys at the hydraulic shop said it is good for over 1000 psi without leaking, and that putting clamps on it would cut it.
I'm just going to replace the one line for now and see how it goes, if I like it I'll replace all the lines on both trucks. Having a truck break in the middle of the day makes me lose money while working- having a backup truck at home helped, but I'm trying to eliminate as many things that can cause failure as possible. Both trucks are well over 200k miles, but I don't see any reason they shouldn't be reliable enough to make a trip anywhere, anytime just like a new one... with a little preventative maintenance.
