Hydro-boost leak
Circuit for air horn compressor
Cab clearance Lights
bkaiser
This past week, I lifted the drivers carpet to run some accessory wiring and found a wet firewall and floor! The moisture started at the brake actuation rod, so I checked the master cylinder. It was fine. The power steering fluid was down to just below the 'add' mark. I mopped up the firewall, tried to find some ATF+4 to top off the reservoir (no luck) and headed out for the long weekend. 900 miles later, the firewall is wet again, but no big change in the reservoir. I am concluding that I have had this leak for awhile, and fortunately stumbled across it before the power steering pump cried for mercy.
Has anyone else had this leak?
