Doing the maint on the M-ZT 52, Z Turn mower I checked fluid levels. The Hydro oil fill under the seat of the M-ZT 52 had a line on the oil tank that said "FULL WHEN COLD" it was good to go but was looking on cap of the tank it said "20w 50 oil? (I'm assuming its hydrostatic because it says Hydrostatic & Commercial on a sticker on the drives)
OK WHAT KIND
looking in the owners manual it came up with this???
Transmissions on the consumer zero turns and tractors are maintenance free. Consumer zero turns and tractors do not require regular fluid change unless regular service is notated in the owners manual
Swedish Riders 16 (H), RIder 155, and Rider 175 use 10w-30 non-synthetic engine oil. Rider 175 AWD and Rider 155 AWD use 10w-40 non-synthetic engine oil. NOTE: Fluid change for the Swedish Riders needs to be performed by an authorized Husqvarna Service dealer due to the complexities of the drive system.
Below are the common models that require drive fluid changes as part of the listed maintenance schedule.
EZ, MZ, and earlier ZTH commercial zero turn mowers use 20w-50 non-synthetic engine oil. The fluid capacities are listed in the owner manual.
iZ, LZ, BZ mowers use 15w-50 synthetic engine oil, capacities are listed in the owners manual.
If you are experiencing fluid loss or loss of drive, the mower needs to be taken to an authoirzed service dealer for evaluation and repair.
4th paragraph shows the MZ 20w-50 NON-Synthetic MOTOR OIL?? if this is true ITS LIKE WATER CLEAR
which made me think BS that ain't normal motor oil.
I dont have any leaks and the level was Good but I would like to have a quart on hand JUST BECAUSE. With the mower shop in town closed WELL HERE I AM trying to stay OCCUPIED & prepared
BIG
OK WHAT KIND
BIG
