rbattelle
I've begun reading the latest TDR issue, and there's a short section in there (whose author I can't recall right now) which mentions the hydroforming technique used to make the 3rd gen. frame. He claims that hydroforming works just like stamping except that "water is involved". He also claims that the 4th side of the boxed frame is welded in place.
Correct me if I'm wrong, but I believe this information is wrong. Hydroforming of tubes is normally accomplished using a die and high pressure water, which is forced under high pressure (1000-6000 bar or more) into the center of the section you're trying to form. This causes the steel to expand to fit the shape of the die. The resulting part is all one-piece, so there is no welding required (which is the whole point - that you've eliminated residual stresses associated with welding).
From what I've read, the process is carried out at room temperature, but it seems to me that more efficiency (uniformity) could be achieved by doing it at elevated temperature. This might, of course, dictate the use of something other than water.
If Dodge is actually stamping the frame sections then welding them into a box, this is not hydroforming. However, I have heard of machines which use a single die and a large rubber bladder filled with pressurized water which is driven down into a piece of sheet metal backed by a die. Such a machine is similar to stamping, so it does not have the same strength benefits of a true tubular hydroformed part.
So is Dodge using tubular hydroforming on the 3rd gen. or not?
