The first law of thermodynamics can't be circumvented. It requires more power to liberate hydrogen from water than is provided by burning the hydrogen.
If this weren't the case, every power plant on Earth would be running on hydrogen generated from water.
Ryan
I was @ Mass Diesel a couple of weeks back having a LOF done, and there was a white 04 from NJ in there that was running twins, and lots of other go fast stuff. Interesting thing is that the truck was in there to have an HHO generator installed...
I have a friend who made one of these HHO generators for his 2002 Cummins/Ram, and his mileage increased from 17. 0 MPG to 26 MPG as long as he dosent go over 2K on the engine.
To have a reasonable discussion, we need to separate the rather dubious idea of “water as free fuel” from the idea of hydrogen as a combustion enhancer. Most of us agree that you cannot simple split water, burn it in an ICE and need no other source of power.The first law of thermodynamics can't be circumvented. It requires more power to liberate hydrogen from water than is provided by burning the hydrogen.
Ryan
I can’t help but imagine the initial reaction to the guy who developed the turbo. When he spoke of his plans to restrict the exhaust to increase the velocity, then put a pinwheel in the flow and connect it to another pinwheel to push more air into the engine, people must have been all over him saying it would not work because you cannot get more energy out than you put in!
Research where? Everything that looks promising now cost $$ to see on the net. Do you have any links to any open information? And our diesels burn way lean all the time, so what do you mean by "lean burn"?Actually, the technology was already proven with blowers by the time the Swiss guy built and patented the first turbo over 100 years ago. The addition of the turbo alone didn't improve efficiency, it simply permitted higher fueling (or higher altitudes in the case of airplanes). Not much to argue about there. LOL, does that matter? I bet there were still plenty who would say it would not work!
If you do your research you will find that the amount of H2 required (not hho) to create a lean burn is quite high. It's not a mystery, it has been well documented.
Seeing the reactions in these threads, I can't help but imagine the initial reaction to the guy who developed the turbo. When he spoke of his plans to restrict the exhaust to increase the velocity, then put a pinwheel in the flow and connect it to another pinwheel to push more air into the engine, people must have been all over him saying it would not work because you cannot get more energy out than you put in!
So what is your contention? That H2 can work as a combustion enhancer but it requires more H2 than is practical to produce on the fly or that the hydrogen does not enhance the combustion at all?
TMax, with a good supply of H2 you can displace some diesel. If you seriously want to consider bottling up some then forget about the home made generators. You need an electrolyzer with either diaphragms or ion exchange membranes to separate the H2 from the O2. You don't want to compress those mixed gases. Here is a link to several manufacturers of electrolyzers that have the ability to directly compress the separate gases.
Hydrogen & Fuel Cell Investor
Add solar and/or wind turbine to power the unit and you'll be as close to free energy as you can get.
To expand on the "why don't the car makers use it" argument and not just for this technology, but whenever that argument is used:This argument is lost on me. A turbo does not produce any energy at all. A turbo merely extracts some additional energy that would otherwise have been exhausted and uses it to produce work. The laws of thermodynamics are obeyed. The turbo restricts the exhaust robbing power, just like a restrictive muffler does. The turbo is not free energy, though its positive benefits far outweigh the small energy cost to operate it.
What do you mean when you discuss "enhancing combustion"? By making a more complete burn? I'm no chemist, but I don't see how adding a fuel is going to cause more diesel to combust, unless combustion temperatures increase which may (or may not) encourage better vaporization and (possibly) result in more fuel being combusted. [Of course, higher temperatures are going to generate more oxides of nitrogen]. But then, you must account for the fact that the hydrogen you've provided is going to consume some of the available oxygen. If you do a search on propane and CNG they say both act as an combustion enhancer too. I really don't know either, but I can see where any combustable gas will mix with air to make a more homogeneous mixture as compared to vaporizing droplets of diesel. Our diesels are always (or almost always) running lean so there is always sufficient O2 available. It might be that the O2 does not mix well with the vaporizing diesel in the short time of the combustion event so there are in essence local shortages of O2??
But in the end, there's really no point in arguing about this. In general, most people decide their opinions about how things work, and no amount of arguing really ever changes anyone's mind. Same thing with fuel economy - if someone decides he's getting 26mpg, no amount of proof will convince him otherwise.
My neighbor is convinced he gains 3mpg in his Kia Sportage if he adds a tiny bit of acetone to the tank. He probably does, because he probably drives in a way that confirms his belief. I've heard that it reduces surface tension allowing better fuel atomization. Who knows? Maybe I'll try it in my beater and let you know, lol.
There are many thousands out there getting up to 40% better mileage with fuel line magnets! Um... yeah!
If these things work so well, why aren't they standard equipment, given the need to meet CAFE and the fact that, in today's economy, fuel economy sells. I know, I know, the car companies are in cahoots with the oil companies. Of course, that doesn't explain why Honda offers a CNG civic and has just released a fuel-cell powered Accord. Thats the old standby argument. The reality is: The only thing that can be inferred by the manufacturers not using a technology is that they feel it would not be profitable for them. Thats all. Period.
I'll tell you one thing, though, it is fun to argue about this stuff! Yes it is as long as everyone keeps it good natured!
Ryan
Sweet. Please make a thread on it when you get it done.Little Bill,
I guess I'm halfway there since I will be installing a grid-tied photovoltaic system on my roof next month. I think I'll be selling power back to the utility company 6 months out of the year. Now if I could only get that for free!:-laf
