I'm pretty sure that I won't want to drive a H2 powered automobile. The power-gods in Detroit might surprise me, but, I just don't think the chemistry and the physics will work out for one that I'd enjoy
and you say, "Rich, why the pessimism?"
to which I answer, "Bond reformation energy sorely lacking
and many of you get the "deer in the headlights" look
Here it is, Hindenburg not withstanding.
Hydrogen's a low-temp fuel. The Hindenburg's conflagration released a buttload of BTU's, but that's because it was a buttload of cubic meters of gas. In the kind of premeasured quantities that you'd use in a controlled combustion situation, like a car engine (notice I didn't type "truck engine"
?), there won't be many BTUs produced... . and you say, "that's OK, it'll run cooler
" and I say, "if it'll run at all"
Here's the reasoning. I know the BTU's per gallon of gasoline (approximated) and I know the BTU's per gallon of Diesel (also approximated) I don't know the BTU's per cubic foot of H2, but, if you want specifics the number's gotta be out there in cyberspace, and you could stick it into the math yourself. For now, let's examine some applied physics in the present "real world"
My 7,000+ lb truck gets approximately 17mpg in "urban mix" driving. I happen to know that one gallon of D2 can liberate approximately 14,000 BTU of heat. From this, I can state that I need about 823 BTU per mile to drive my truck.
(14000 BTU/gal divided by 17miles/gal= 823-ish btu/mile)
if all other measurements remained equal, running the same load on the same distances, pushed by gasoline would require the same 823BTU/mile, and so, more volume of gasoline for each mile, cutting the MPG to about 14. 5mpg, due to lack of intrinsic heat in the fuel
Now, for the chemistry.
Both gasoline and Diesel are hydrocarbons. For easy typing, I'll treat them as pure chemicals, rather than the mixtures that, in reality they are.
Gasoline is a saturated Hydrocarbon chain of, like 8Carbons and 18 Hydrogens, commonly schematic'd like this:
H H H H H H H H
H-C-C-C-C-C-C-C-C-H
H H H H H H H H
Diesel is a longer chain molecule, say, for the sake of comparison, 10carbons long, and with 22 hydrogens.
I'm not typing one of those... use yer imagination...
Where does the heat come from?
Oxidative burning (if complete) of the imaginary gasoline fuel molecule releases heat proportional to the breaking, and re--bonding (with O2) of all those bonds, which lead to 11 molecules of water and 8 molecules of CO2
If you do the same to the sample of Diesel, which is a longer, heavier, more oily, molecule will yield more bond-breaking and reforming to make more molecules of H2O and CO2, AND MORE HEAT!!
H2 has NO carbon, and just a single covalent bond to break.
There simply won't be a lot of BTU/ unit of measure available, compared to hydrocarbons...
will need bigger tanks, and lighter vehicles... I don't see them having any power or range...
(some of you cyber-pic whiz kids can probably find a pic of Steve Urkel's BMW Isetta, and the Graf Zeppelin, and put them together like the Zeppelin is the Isetta's fuel tank..... get the picture?
) Since its exhaust would be, simply, pure water, call it the Dripmobile!
There might be one neat design, however... . don't go reciprocating piston for an H-motor... Go with a gas turbine for more efficient use of the thermodynamically anemic fuel... at least you'd never need to monitor EGT's
I'm not even going to mention that hydrogen generation requires electricity to produce... . trading wall-plug power for foot-throttle power... .net energy expenditure would be heavier because of that.
H H H H H H H H
H-C-C-C-C-C-C-C-C-H
H H H H H H H H
