John, This rub rocks. Try it this summer
Hugh's Dry Rub.
Servings: 36. Use this dry rub on your favorite meat before grilling. It stores well in an airtight container.
8 tablespoons Hungarian Sweet paprika
3 tablespoons cayenne pepper
5 tablespoons ground black pepper
6 tablespoons garlic powder
3 tablespoons onion powder
6 tablespoons kosher salt
2 1/2 tablespoons oregano, dried
2 1/2 tablespoons thyme, dried
In a medium bowl, combine the ingredients. Mix all together well and store in a cool, dry place in an airtight container. Yield: 2 cups. I use one of those Tone's bulk spice containers you find at Costco for storage, right size and has a shaker type top.
Personal notes: Killer rub for most meats. I haven't used this on Salmon because I have a different method for Salmon. But, Pork spareribs, babybacks and other pork products respond especially well. Generally, I marinate the pork (plastic bag) in Apple Cider Vinegar for a minimum of 1 hour, not to exceed 24 hours, drain vinegar, sprinkle Rub on the pork, how much you put on determines how hot this tastes. Gently rub in the Rub (Note: I use surgical gloves, those cheepy things you get at Costco, because this rub will stain your hands, and if you've got open cuts, you will wake up), let set on counter about 1 hour. Take out to the BBQ. I generally cook the pork indirect method, about 350-400 degrees, takes about an hour, meat should be about 160* when you remove it. The key thing to note about this Rub is that you change the degree of heat by how much you apply, the amount of cayenne pepper you add. This recipe makes alot of Rub. You might cut it in half (1 cup) or even quarter it for experimenting with. Note about the vinegar. You will NOT taste the vinegar in the finished product unless you overmarinate, exceeding the 24 hours. As I said, great on Beef and Chicken as well.
Sorry I got wordy but this Rub and others broke me away from "commercial sauces".
Too much sugar in most of the tomatoe based sauces.
BBQ is a year round cooking method for me.
