I Bent my Steering Center Link
So I am crossing this rather narrow very steep and deep ditch (I am taking it with lots of angle) and find that my truck is refusing to do it.....
So I back the front wheels up to the in going side of the ditch and get a little momentum going, skinny pedal to the floor in 4WD HI (all 6 spinning). I finaly make it up and out! all is going well until I notice my truck is driving funny
I notice when going in a straight line I must put the steering wheel about 1/4 turn to the right
All I can figure is that when I took the ditch at such an angle (ditch was steep enough to make driver side wheel leave the ground) it put ALLOT of load on the passenger side wheel causing it to want to go left therefore bending the center link (goes from the pitman arm to the drag link).
What is this link called? Edit: It is the "Center Link"
Am I special or has this happened to others in the past?
And this link is supposed to be straight or have a little bend like mine??
Thanks in advance.
Thanks in advance.
