Here is a modification I did to my M-25. Normally during competition, we use a sock filled with sand placed under the stock to get the right elevation. I decided to take that one step farther and make something a little more precise. I took a 1 inch bar stock of alluminum, and formed it to the same contour as the stock, and then I drilled and tapped the bottom to take a 5/16 inch bolt. I mounted the recoil pad to the alluminum block, and this is what I ended up with. Now all I have to do is look through the scope, and turn the bolt until the crosshairs are dead center. I put a piece of metal or plastic under the bolt when I fire so the recoil of the rifle doesnt put a side load on the bolt. The next modification will be a custom cheek piece that is formed to the contour of my face. This will assure exact eye relief for each shot.
