HTML:
It won't make a very big standby gen set. Engine hp to kw output on small generators is usally 2hp=1kw. 8hp=4kw. Also, being it's only a 2-cylinder, and depending on the engine rpm, you may notice a flicker in the lights since it so long between power strokes. With a 2-pole alternator, the engine will have to turn 3600 or a 4-pole it will have to turn 1800 in order to deliver 60 cycles.
I have a 2 cylinder Westerbeke 4. 4 kw generator in my boat, circa 1983. Runs at 1800 rpm, no flicker, smooth and quiet (note exhaust is water cooled). It is rated to use about 1/3 gal per hour at full load.
The engine is rated at 13 hp at 3000 rpm but obviously less at 1800 rpm.
