Filled my DEF tank two days ago and today I got CEL with a OBD Code P202B - Reductant Tank Heater Control Circuit Low. Anybody got this before and what did you do to fix it?
Thanks Ron, I did order a scanner last night on Amazon, should be here tomorrow. Looks like I need to bring into the garage and check all the electrical connections. It’s a 2018 with 71k miles so I need to see if it’s covered under my extended warranty if it’s not something simple. Thanks again for the response and link.
I get that code everytime that it gets in the low 20's out. Basically the shop says the heater in the DEF tank is bad, and the fix is a new DEF pump. They quoted me $1600. This has been going on for several years. I just run with the MIL lamp lit all winter then clear the lamp come spring.
