I put truck in reverse and had a bad vibrating shutter. Thought it was the trans, so we pulled the pan to check the reverse band adjustment and it was fine and nothing in the pan. Hooked up a line pressure gauge and stuck it in reverse pressures started at 200psi and climbed with throttle. So we decided it might be in the rear end. When I powerbrake in reverse there is no shutter but as soon as I let it roll it shutters like a clutch is chattering sort of.
Pulled the rear diff cover and found one little metal shaving and nothing else. The oil still looked clean and nothing in the bottom of the houseing. Heres the weird part (at least weird to me) If I put the truck in 4 wheel I can back up with nothing going on. As soon as I back up in 2 wheel it screws up.
We are now thinking maybe something with the ABS system?
Any thoughts
Steve
Any thoughts
Steve
