I gotta Question!!
Wisconson TDR members I need help
Intake Hoses
I just received my Rancho 2" steel spacers and am having them installed this evening. I bought them used and they are in VERY good shape. My question to you guys that have them is, "When you order the 2" leveling kit(just the spacers, not the links) do you only receive the spacers" The reson I ask this is becuase I have no instructions or installation guides. I started to install them yesterday, but i wasn't sure how they went on and i didn't have a spring compressor. They have bolt holes in the tops of them so I just figured that you turn the three existing bolts over and tighten them down. :confused: :confused: Thanks. I'll post a pic whenever They get installed.
Chris
these instructions are for my tuff country spacers,,should be the same. you can get the lower control arms,,but i didn't. mine had the bolts tack welded to the spacers. you could use bolts but probably wont be able to reach the inside one to tighten it. use the spring compressor if you can. i didn't and it was real tight getting the spring back in. GET IT TO AN ALIGNMENT SHOP ASAP!!
