Ok, short story. .
Recently I broke my Differential. (don't ask how, I just did
Well, my local shop "fixed it" with some old "spider" gears, and the other day (Friday the 20th) it broke again, I assume a bad part.
Well, both times it broke, it took a few gears out of the "tone ring". This ring that tells the Rear-Wheel Speed sensor how fast the rear-end is turning, it also tells when to apply the ABS.
Having a tooth or two missing from this ring puts the truck into ABS mode and I have to stop with my front brakes only. (Rear wheel ABS) This problem has caused me to skid to a comlete stop several times, beacuase the ABS turns on, and I loose all rear braking. (try stopping 7. 5 thousand pounds with only 490 millimeters of rubber. )
I called my local Dodge dealer, and quoted me $235 for this tone ring, and I figured I would put my money somewhere else instead.
Now I need to know how to disable the ABS pump the proper way.
Has anybody ever disabled this pump? I know I COULD just pull the fuse, but I was hopiing I could disable it somehow without having my instrument panel light up like a Christmas tree.
I got around to thinking if I could make the ABS pump turn on and off Manually, it would be really helpfull, and right down cool.
I was hoping this might be done as easily as maybe just crossing two wires close to the pump, to make it turn on with a switch.
Any ideas?
New differential will be installed on Friday the 27th and the truck is wearing out front brake pads very quick, with this ABS situation.
Thanks,
MerrickNJr
Any ideas?
Thanks,
MerrickNJr
