I have info on 24V LP issues...
My LP recently died. DC updated me with the new intank lp yesterday. I have the common 7 psi at idle, 5 psi cruising, 0 psi wot readings. I contacted my local Cummins dealer and spoke with a acquaintance that is extremely familiar with the ISB engines and the dodge truck systems. The word from Cummins:
-fuel PRESSURE is not the key anymore. It's about volume.
-The intank pump is the answer to eliminating the problems asspciated
with the carter lp
-Any VP's that were newly installed after Jan 05 are an updated pump that is
more stout
-Having run a newer VP on low fp will not damage it.
-TOO MUCH fp is a serious problem on the vp's. High fuel pressure will kill the
pump over time. ( I don't have a specific figure here, but 24psi is WAY too
much)
-The higher VOLUME of fuel helps to keep the vp cool and lubricated.
I'm not looking for any flames here, just posting what was relayed to me from a very reliable source. I feel this info should be known just because of the number of problems that everyone has had with their lp's.
Eric
with the carter lp
more stout
much)
Eric
