I just lapped myself at 400
Go Lakers!!!!!!!!!!!
what does iota(sp) mean???
Pity about losing more than 125 posts from my counter, when the missing archives were restored on-line recently.
It would be neat to get them back Mr. TDR Admin... ...
Steve has done all that he can on this matter.
Honestly ask yourself, whats more important..... "my" post count, or having a ton of useful information available?
Other then Illflem I probably took the biggest hit on post count loss.
Originally posted by KatDiesel
whats more important..... "my" post count, or having a ton of useful information available? Other then Illflem I probably took the biggest hit on post count loss.
You're absolutely right - it's a no-brainer - just me thinking out loud..... In my line of business (cellular communications) when we do upgrades or system enhancements, there is always a backout plan as well as a point of no-return for some occasions, which if invoked, will be dry-tested first off-line, just so that customers don't experience a degradation in service at the big cuttover.
JMc
Originally posted by dresslered
Don't forget where you're located, John. You're on the metric post counter! :D
... aren't we all? How does it feel to be a "TDR virgin" again at your age David - hold onto that testosterone :D:D
JMc
Originally posted by Rammin On
The post counters are stuck anyway ... ... . how many # 404 posts can you make?????
Not sure if this is a sarcastic or a honest question?
Your post count will update itself... ... just like your signature will.
If you change your signature... it will change in every old post. Its the way the software works.
If you make another post on this thread yours will go up by 1 post. It will just have the same number for the whole thread.
If you already knew this then I apologize.
Kat ... .
Just playing around ... ... boordom sets in every now and then ... . so I thought I'd grab my spoon and stir the pot ... . worked eh???
Life is good!
I've tried to explain the problem but maybe I haven't done a good job, I'll try again. At this point the only way I could restore the post counts would be by going into the archives that I restored and counting up the posts for each user, then manually editing 12,000 users records by adding what their current post count is to what was in the archives. Sorry, but that isn't going to happen - you'd be talking about hundreds of hours of work to manually edit all those records. On top of that if it was ever necessary to do a recount again (because the database was corrupted, etc) then it would have to be done all over again.
When you import messages into vBulletin you have to rebuild the indexes and then redo all the counts. When the initial switch was made to vBulletin and everything was imported into it the user numbers did not match because there were a couple of users already in vBulletin (the admin accounts). Because of that I was unable to import the old messages and keep them attached to original users. The only way to do so would have been to fill out a table manually with the current user number for 12,000 users. I went through a few and timed it to see how long it would take - it was over 100 hours just to line up the user numbers. That wasn't cost effective to say the least. So I had to import all those messages to the user Archive. Then because of the necessity to do a recount (which had to be done because of the import) - poof those counts of the old threads were gone.
I did the best I could given the data and tools I had at my disposal. I lost over 1000 posts on my personal account as well. A decision had to be made whether to import the old data, or to lose some post counts.
Steve St. Laurent
(TDR Webmaster)
Steve-
You're doing a great job! We are just AN overly picky bunch! I even have to have my gear shift knob rotated to precisely 2:00 o'clock for proper visibility. :D
Steve ...
No shots being taken at you ..... not that I see ... I think you explained it well ... . myself ... I was just having fun ... who cares about post counts anyway???? and why should they????
I hope that's not why people are here ... . just to get post counts up ... . maybe we should just zero everyone out ... . then watch as the post count watcher raise the dead!!!:D
Thanks for everything you do to keep this site running so well ... .
Life is good!!
Keith
Steve-
Agreed, Steve does a phenomenal job. And my shift knob has to be at 11:19 to work properly. I'm considering 11:30 or so, but one has to weigh these decisions carefully.
Perhaps instead of counting each user's old posts, TPTB could just take our word and restore the numbers for ~12000 of us manually. By my best reckoning, I've lost about 4374.
Jim
