What should the stock turbo on an '03 H. O. read on the boost gauge? Mine, at wide open will get to 25psi and decrease as the engine load levels out. I'm reading on here that people are getting almost 40 psi!!! Just cruising mine will hold steady at 5-7 psi and 0 psi until the rpms get to about 2000. Has anyone experienced this on their '03? Also, when the local diesel shop had their scanner hooked up to it several weeks back he thought it was dd because the scanner should 19 psi at idle. Later on a diesel tech at Dodge told me that the common rail engine should have at least 15 psi at idle. My readings are coming off of the boost bolt in the manifold. Would the boost elbow give a different reading?
