I need a headlight
Installed Skyjacker Dual Damper
Diprocol parts
I need a headlight does anywhere know where i can get a good deal on one. I might consider the clear ones if i can get a good deal on both. Dealer quoted me 180 for the full assembly and 110 for just the headlight. Thanks for the ideas
Trey
What is the difference in the sports and will they fit in a 2001 2500 without modification. If so i will take them let me know how much just send me a pm.
Thanks
Trey
The difference is four bulbs instead of two. No sheet metal modification on model years 2000-2002. You will need a wiring harness. You can make the harness or have one made at SUV Lights.
You won't regret this modification.
Originally posted by tpruitt
what harness would i need to order and whats the part number. thanks
Read the questions and answers on the SuV Lights site. Pay attention to the questions that involve dual batteries. When you convert to Sports you will use a 9004 socket to control both a 9004 bulb and a 9007 bulb. Your Ram uses "switched ground". A telephone call to SUV Lights should get you an answer. It is possible to get the "Brite Box" feature built into a custom harness at little increase in cost.
