diesel designs
Sorry for not getting back sooner. Why I ask is because mine has always.
The injection cycle has always been irratic by ( this is caused by the bad electrical from some componant ) this I mean on the different cylinders get varing amunts of fuel , this I can tell because of the different thumping in the seat, and the varied shaking of the engine. Some years ago when going up a 10 % grade 2200 rpm the engine shuttered vary violently at the speed of a transistor being turned off on offf and back on , it used to do this at 1700 ,1800 and 1900 rpm vary regularly but has since stopped. The other 50 diesel engines that I have operated, haven't done this , so I can tell that the engine isn't operating the way it should.
In July for awhile it was giving me more power; the tone of it was deeper and a little smoother ( other diesels with power for acceleration have a much deeper tone as well , for mine always sounds very tinnny ) Hence for me thinking that the tone tells of the amount of fuel being injected into the cylinder. With mine the tinny sound goes with not having the piston under the right amount of air/ fuel mixture pressure. Also I get for fuel mileage (KM's) I have read on the over head display 7. 4 liters of fuel per 100 km's this was in Alberta on one trip and the weight was from a Ministry of hiways scales for varifacation. MY usual milage is around 22 to 27 miles to the gallon.
Have you by chance got a fax number that I could send you a couple of sheets on what the signals look like ??? If so PLEASE PM me. For it is toooooo complicated for cryslurr and cumins to understand ! When cumins put the brakeout box on the engine it ran much smoother, but I couldn't get the service manager to go further then that with gained info so another dead end.
