On every vehicle there is that little tag on the drivers side door that tells you the recommended tire inflation pressure for the vehicle. (OK got it)
Now you buy a pair of tires,(stock tire size that came on the vehicle) and on the tires is a recommended max inflation pressure. (OK got it)
Now my question is WHY is there so much difference. I relize that if your hauling heavy you should pump up your tires to the max tire pressure recommended. . but... the difference on the tag on the vehicle and the max pressure on the tire will be from 40 - 60 lb's different. It just dosen't see to me that a tire should be run at such LOW pressure when empty.
Example... On my tag on the vehicles it recommends 32 psi... on the New tires I bought it recommends 60 psi. ??????? This is on a vehicle that hauls NO LOAD!!!!!
I'm sure there is a simple explanation from some of you ole tire guru's out there so educate this ole man.
