I need guages. But which ones?
255/85-16?
Stock Shocks
I am ready to buy all my guages. FUEL, EGT, BOOST and maybe a transmission Temp. Which Brands are good and which ones will match my factory dash. I am thinking about a white dash overlay as well so that is a possibility. Thanks for all your input. Diesel Gunner has helped me with dual switch setups so all I need is the guages.
Support our Troops, Support my Friends! Russ Wallis USMC
Russ,
FWIW I have ISSPRO boost and EGT (pre turbo). they are the black ev series. i had the white also but prefer the black. if you go with an overlay in white, maybe the white faced gauges would be perfect. i also have a westburg (westach) fuel pressure gauge mounted in the dash. it has a green condom on the light bulb and looks factory. i went with westach because it is electronic and doesn't require running a diesel fuel or antifreeze line to the cab. Hope this helps.
-Jason
Russ W-If you plan to do the white overlay, you may want to check out the Autometer "phantom" series. They match my 03' almost perfectly. Check out my "reader rig" pics for photos. Another reason I chose autometer is that the sensors have a good rep. for longevity. Good luck with your purchase.
Go to www.autometer.com ,and check out their Cobalt and C2 series gauges they are very sweet :D. I know they are pretty pricey, but very nice to look at. I have Isspro EV series in my truck, and I can't complain, but as far as looks the Auto Meters have it hands down.
the c2 series look great, but their boost gauge in that series only goes to 30 psi... if it went to 40-45psi then :D:D:D
IsoPro Black
I using IsoPro EV black face with the multicolor Pyro, Love them, they are bright at night so get the green bulb covers. They cool
JB
Isspro it is....
Well, and a Westach. I want to thank all of you for the help. I ordered all of my stuff yesterday from Geno's and pretty sure I got it all. I went with the Isspro EV Pyro and Isspro EV Boost for the pillar mount. Then I got a Westach FP guage as well. Happy about my decision with the Pyro and the Fuel pressure, but I might return the Boost guage and go somewhere else. I had a choice of 0-30 or 0-60 so I researched it and found that even with the minor performance mods I want to do I will max out the 30 lb guage so I got the 60 lb'er. I think it is overboard, I will stand strong and not go overboard on the power, but can you REALLY go overboard? I am sure some will say no. Anyway, I might return it and order a 40 lb'er from someone else. Genos was the only place that I called that could answer my questions and had everyhting in stock (less the 40 boost guage). Everyone else either didn't carry it and wanted me to get something else or was on backorder and I don't want to wait anymore. Again thanks for your help and I will have to start a new string on your favorite E-Brakes. Next payday is only 2 weeks away. How about the Jacobs or the Pac?
ISoPRo has 40 pound
There a guage called a manifold guaage that reads 0-40 in the IsoPro series that fit nicely, that I am using.
JB
