I need help depicting codes!
Does anyone drive their CTD
Leaky Fuel Line????????
Hi guys, I installed guages on the 05 last night and when I went for a test drive the engine light came on. When I got home I checked for codes and these popped up. p-0572 p-0107 p-0073. Any ideas what they are? TIA
I'd bet you forgot to reconnect the IAT/MAP sensor atop the air cleaner...
I can't interpret your codes as I have a 2003 manual and it doesn't seem to match up with 2004-up trucks... sorry.
-Ryan
Thanks! p-0572 Third brake light. unplugged a pillar harness looking for ign. on.
P-0107 Had the intake pressure unplugged while putting boost bolt in.
P-0073 Had AIT sensor unplugged while drilling for pyro and installing AFE mag-force intake.
That pretty much sums it up. Thanks for your help. I would have searched for it but the site gave me an error (administrator has disabled search function) or something like that. And dad was freaking out because he didn't want me to tow the GN with the engine light on.
The guages are going to be a big help. I allready noticed I can get the EGT up to about 1300 on top end @ WOT w/ no load in fith gear. The boost guage spikes at 30lbs (no boost elbow) and settles at 25, and cruises at 5-15psi. I got a 15psi fp guage. it usually stays around 10-14psi unless i'm really hammering on it, then it will drop to about 8psi. Oh! this is all with the juice and EZ turned off. The oil pressure guage is nice to have too, hard to believe how inaccurate the factory sim. oil pres. guage really is.
