What I am attempting to do, is have the option of having my high idle kick in anytime the coolant is below the required 140 degrees. My friend is pretty handy with electronics, so he is doing most of this for me. It would be much easier for us if someone with a service manual can tell me a voltage value for a given temperature, or even a resistance value. The sensor I am messing with is the one under the drivers side battery.
So far, all we know is that as the temperature rises, so does the resistance of the sensor, which means as it gets hotter it lets less voltage through and vice versa. We will have to use a pot to find the right amount of resistance/voltage to use if there isn't a good range defined somewhere.
If anyone has the info, it would be greatly appreciated.
Thanks,
Matt
Thanks,
Matt
