I am not sure of your kit. If you are pushing more than 26 psi, you will set an over boost code and your ECMwill start to defuel the engine. To bypass this, just get a potentiometer (sp?) (Volume control) from Radio Shack. A 20 K-ohm one should work. just put it in line between the MAP sensor and the ECM. This way, the ECM will not see accurate but a lower pressure and not defuel the engine. This is all that the fuel boxes do, only they charge a lot more for a $1. 50 piece of electronics.
Just my $0. 02
-Rich
