2nd Gen Non-Engine/Transmission I need some Bilstein shock info, please.
Engine/Transmission (1998.5 - 2002) Good Pusher Pump
Engine/Transmission (1998.5 - 2002) Diagnostic Help
I need the parts numbers and an economic source for Bilstein shocks for Dodge Cummins. It is a 2001, regular cab, 2500, 4WD, no lift kit... I just need to replace the oem shocks (at 68K mi. ). I rarely carry anything heavier than a Honda ATV and I rarely pull or tow anything.
Thanks, Guys.
Bob!
Thank you so much. I was going to ask the same the question. . I called them, 57. 99 out the door with free shipping :--) ! How nice is that!
Thanks again,
Mike
Just a comment related to the Bilsteins... ...
My OEM shocks were no longer controlling rebound at 60k miles. I replaced them with Bilsteins. At 241k the Bilsteins still work fine. They probably don't provide the damping effect they did when installed but they still provide adequate control.
Harvey
Also be sure when you get them that the upper rubber mounts for the front shocks have the steel sleeve in them. Otherwise the front end will eat that rubber mount fer lunch. ;)
