I was having problems with my comp drag box 2 months ago (the module would work about half the time). I sent it to Edge to have them check it out. The rep told me to send in my wiring harness for a checking also. So they sent a new wiring harness and updated my module, so I installed the new harness and plugged in my comp box. Now the module seems to fuel it well at low rpm but as soon as rpm's get around 2,000 the module seems to back the fueling off. I am only seeing 28lbs of boost and 850 egts!! I have good fuel psi and all my intercooler hoses are fine.
So I send the module back to Edge and they send me a NEW module and wiring harness. So I install them both thinking I will have this fixed.
My truck acts the same way. It will smoke at low rpm and about the time the truck should really start to pull hard it seems return to stock fueling levels. 28lbs of boost max and 850 egts. It doesnt matter would stage the box is on same boost and egts.
Now before when my Comp Drag module was working good I would see 38lbs of boost and 1500+ egts in 4th gear.
So a long story short I have been through 2 wiring harnesses and 2 modules with the exact same results.
I have check voltages at my harness end and every connection is rock solid for I have checked these countless times.
My smarty on levels 8 and 9 fuels it harder above 2,000 rpm then my module on stage 5.
I am getting no codes and besides the truck not fueling hard is running fine.
ANY IDEAS???
ANY IDEAS???
