I need some help on a tst cr????? please
those of you using volant air box
Sticky Clutch Pedal?
I just put one on tonight and was wondering where to run it with a crazy larry on not to run together just give me some input please on hpw to get to most put of both... Thanks TJ
I would say try the Bullydog Downloader on the 50-60 hp setting. Then dial up the TST till it suits you and the EGT's you are ok with
Keep in mind just the TST has enough to kill the egts, and make tons of power with proper airflow - Add the dl'er. and you just compound the EGT problem
I will say that I hear that the bullydog Dl'er will get the fuel into the engine earlier then the TST alone, therefore helping the TST get started...
Let me know if you have any other questions, Keep in mind that the fuel is super easy to get, but hard to burn effiecient and get the power to the ground
Crazy Larry is a hotter program for the Power Pup... U have the normal tow( 50hp). . performance (90). . and extreme (130hp) programs plus the Crazy Larry (200hp) I believe. . I might be wrong on the hp of the crazy larry setting but i know it is around 200 hp
Moose
The Crazy Larry Program is a 200hp program on the power pup downloader that is only available for 04. 5's and up. It makes some power but is pretty hot. 1600* in no time.
here is a quote from Piers about stacking the tst and crazy larry program.
I've run the TST twin version on my truck for several months now, been working fine. Other than a cam, for fuel mileage, & the street/strip twins, the engine is stock. The TST put out 565hp. we tried a Bully Dog Crazy Larry program & it put out 554hp. Tried them stacked, Bully Dog on Crazy Larry & the TST on 7 by 6 and it put 675hp to the ground. We tried going higher on the TST program, but lost hp. Got some injectors coming... . maybe we can break 700 with some new sticks installed.
now keep in mind this was not with a stcok charger and even with twins it probably got a little hot. Not too mention don't forget about the poor transmission! :D Hope that helps.
Now thats what Im talking about I want to have lots of power when I want it and I really want it to SMOKE like all get out when I want it to,Just to get those pesky tailgaters off my BUTT I hope I can figure it out. . The different combos to try it on. . Without having too many problems. . Thanks for all the help!!!
and keep in mind there were some that called me crazy and uneducated when I stacked the bullydog with the tst last year. :D
