Engine/Transmission (1998.5 - 2002) I need some help with replacing the seal on the output shaft of my transfer case.
I had it replaced a couple of years ago and I guess it didn't hold for very long so I need to know how hard and how I change the seal because I think I have lost quite a bit of fluid because it is hard to get into first now at a stop. Any sggestions on how to avoid another replace would be appreciated also. Thanks in advance.
LineMan.
Hope this helps you.
#1
MFranz
Online
Transfer Case leaks.
Recently changed transfer case fluid on my 2001. I overfilled it and have since developed a leak at the rear seal. Its leaking that reddish fluid at the rear output shaft. In addition there seems to be another leak of a different kind on the bottom of the transfer case near the bottom bolt where the case bolts togeather (a dark oily kind). My questions are,If Im going to replace the rear seal on the transfer case should I replace the Extension Housing Bushing at the same time.
The service manual states that you need to have
special tools to do this removal and installation,your thoughts. Regarding the dark oily leak on the bottom of the transfer case,could this be from the transfer case or some other source. Thanks in advance for any Input,this is a great resource and we appreciate your help.
Thanks
Mike
MFranz
View Public Profile
Send a private message to MFranz
Send email to MFranz
Visit MFranz's homepage!
Find More Posts by MFranz
Add MFranz to Your Buddy List
05-10-2005, 04:30 PM #2
Crowhurst
Offline
Mike, the service manual has to deal with the worst of all possible cases. I just replaced the rear seal when it leaked, and that fixed it. Nick.
__________________
98 12 valve auto 4x4 quad cab long bed, 3. 54 diff, towing Airstream 25 ft travel trailer, 6500pounds. BD e-brake, autolock, pressurelock, Jordan 2020 brake controller, KDP fixed, DSS steering bracket, Rhino bed liner, Solidsteel 3rd gen track bar bracket.
Crowhurst
View Public Profile
Send a private message to Crowhurst
Send email to Crowhurst
Visit Crowhurst's homepage!
Find More Posts by Crowhurst
Add Crowhurst to Your Buddy List
05-10-2005, 04:38 PM #3
Crowhurst
Offline
Mike, you might like to look at this thread, which discusses this issue https://www.turbodieselregister.com/...28&page=2&pp=15
You will see the care needed to get the correct part number for the seal. There are several different numbers. Nick
Crowhurst
View Public Profile
Transfer case leak.
05-10-2005, 05:37 PM #4
MFranz
Online
Transfer case leak.
Thanks Nick. I got the heavy duty one. Part #05086054AA
from Dodge. $50 and that was after Discount. Steve had replied to another post that I had made on this subject.
I appreciate all the input. The power of the Internet,Its great. Whom could Imagine that you could ask a question
and receive answers within minutes from around the Globe.
Thanks Again
Mike
MFranz
View Public Profile
05-10-2005, 07:40 PM #5
FANZDSLPWR
Offline
how do you replace the seal? my 96 transfer case is also leaking
FANZDSLPWR
View Public Profile
Send a private message to FANZDSLPWR
Send email to FANZDSLPWR
Visit FANZDSLPWR's homepage!
Find More Posts by FANZDSLPWR
Add FANZDSLPWR to Your Buddy List
Transfer case seal.
05-11-2005, 12:14 AM #6
MFranz
Online
Transfer case seal.
Here are some of the things that I did for my truck. Its a 2001 3500 4x4.
Raise and support Vehicle onto saftey stands. My tires were just a couple of inches off the ground.
Put transmission in neutral making sure that the parking brake is on.
Use a marker to mark across the the axel pinon yoke and the driveshaft.
Use a marker to outline the center bearing on the frame cross member for reference if so equipped.
Use a marker for reference were the driveshaft yoke enters the transfer case.
Remove bolts that attach the center bearing to the support bracket if so equipped. Mine were15mm.
Remove the bolts holding the universal joint clamps to the Pinon yoke.
Slide the slip yoke off of the transmission or transfer case.
Take old seal out. Use of a hammer and an old screwdriver or chisel to tap the old seal out. Tap from front of vehicle towards rear on the outside of the transfer case.
Clean. Use steel wool or emery cloth to clean up any burrs or nicks.
Tap in new seal with weep hole centered on the bottom.
I used a 3 1/2 " PVC fitting which was the perfect size for my seal. Not all models are the same.
Install in reverse order.
I tested my truck while it was still on the jack stands. I started it and let it idle in drive and watched the driveshaft
to look for any problems.
Test drove. No leaks so far.
About 3 hrs labor for this slow shade tree mechanic. A real one could do it in less then an hour.
GoodLuck
Mike
MFranz
View Public Profile
05-11-2005, 01:35 PM #7
Mactruck
Offline
View Reader's Rigs Gallery
Dumb question (on my part)
Why do you need to mark the driveshaft in line with the yoke?
I've pulled mine off a bunch of times and never lined them up. (or maybe I should have)
I thought there was a slot that prevented you from sliding back on EXCEPT one way.
__________________
**My Quad Cab**
Mactruck
View Public Profile
Send a private message to Mactruck
Send email to Mactruck
Visit Mactruck's homepage!
Find More Posts by Mactruck
Add Mactruck to Your Buddy List
Transfer case leak
05-11-2005, 03:12 PM #8
MFranz
Online
Transfer case leak
Mac,I dont know. First time Ive done it. Thats what the service manual said to do. Being the first time I wanted to make it right . Maybe someone else can shed light on the subject. I used the marks as a reference in putting things back together.
ShadeTree Mechanic
Mike
