I need the AC evaporator and heater core for my 1993 D250
Heat Blend door cable.
Rear Bump Stops (suspension part)
Hayes Dodge dealer in Atlanta told me both are discontinued and none available. He gave these part numbers: Evaporator #4882988 and Heat core #4361181.
A nearby parts store had an aftermarket evap by Global Parts (#4711241). It is close but absolutely will not fit and is much less heavy duty. I think NAPA sells the 4 Seasons brand (TEM 282992) but the photo looks to have the same problems. Apparently the aftermarket listings are dead wrong! They won't fit a 1993.
Please respond with any sources or ideas to get my truck back on the road. Thank you, James
Have to remember most aftermarket parts will look a bit different from the original. In the end I believe it will depend on the quality of the install. May have to do some downhome fab work sometimes to get it right. Whats different from the original ?
Thanks for the response. I'm no stranger to "downhome fab" and maybe could bend the pipes and pack foam rubber around it to seal the gaps but that really is a last resort. The aftermarket ones are very obviously less efficient: about an inch thinner, 36 tube passes instead of 50, less fins per inch. These things are garbage compared to the OEM I removed. I'm doing this job because the heater sprung a leak. I'm not real sure the evap needs replacing, I just have had to add 12oz of FE12 every year and couldn't detect a leak anywhere else. Maybe my old evap could be cleaned, tested, repaired????? I've had this truck since 1997 and hope to keep it forever!
