I think I need a bigger Turbo......
WESTACH boost and egt gauge users
Carefull, super plug leaking
Just installed Super Mentals and now my EGTs are hitting the 1550* mark. . Where are you guys getting the twin turbos from? Also I looking to upgrade my cam and port my head. Thanks.
I see in your sig that you are running an HX40 with a 12cm2 housing, is that correct? If so you may want to consider going to a 16cm2... A good head porting will do wonders for your egt's as well.
I too would like to know about the port-n-polish and how it effected your EGT and spool up. Also if you don't mind, how much did it cost to have it done??
JR2
Devildog,anything you use that it bigger will affect spool up. Twins are the only thing that may keep your EGTS down,and have little turbo lag.
