Ime so screwed. I was going to work today and when i pulled to a stop light, my truck died. WHAT??? i said... Fired it up and got moving and pulled to the next light and i almost had to use both feet to keep it from moving. Engine is just fine. So i take it right to my 5 star and was ideling in neutral. Put in in drive and it dies. Start in neutral. Put it in drive and dies again. After a few times it will keep running but at about 500 RPM and is really lunging forward. Dodge wants 9 hrs to pull it and check the transmission. There are NO codes they said. I was stopped on the way home tonight and it was still doing it. At one LONG lite it was barely running then there were a couple of those "very expensive sounding noises" like if you missed a shift on a manual. Now, i think the converter is locked too, but, i can barely manage an idle some of the time. When ime up to speed, it seems normal. I can tap the brake and feel it unlock and lock right back again.
feedback and advise would be most welcome!! RRR P. S. I bought it used with 40K miles and a very expensive looking sub mounted Towing "ball" in the middle of the bed. ???? Who knows what that was used for... ...
1999 bone stock 4x4 Quad diesel.
