I want to stack a fueling box with the new Juice
708hp with EDM's with a HPCR
Which Filter
I'm wanting to stack a fueling box with the new Juice. I'm considering the following: EZ, Predator stage II and Dr. P stage II. Which would you recommend and why? Where to buy and price if you know it? Got one to sell,... PM me. Must be for the 04. 5.
Tks.
Same here, Edge designed it to work with the EZ, however, most pressure boxes are the essentially same. The EZ has an increase of 70 rwhp and some of the other pressure boxes give around 100 rwhp. I would be careful stacking it with one of those due to the extreme pressure increase at the highest setting.
Overall, I recommend the EZ because Edge's customer service is one of the best. As far as a place to buy -- Search around online, I have an 04, not the 04. 5, but I would think if you hunted around you should be able to get one for not too much over $425 or so. Hope this helps!
just to be picky here: the juice is itself a "fueling box". sometimes we confuse the term "fueling" with "pressure". But the juice increases fueling by stretching duration.
but with that little detail out of the way, yea I agree -- stack the juice with 70HP or less (there is only about 65 horsepower available via rail pressure increases anyway, from my experiments). a 50 horsepower pressure box would stack nicely as well, but the nice thing about the EZ is that is has four adjustment positions so you can pick which one works the best. Also, Edge will probably be more willing to support you if you used both boxes with their label on it.
Will the Attitude controll the Juice and EZ at the same time, or will I have to keep the EZ manual and only adjust the Juice on the fly?
another interesting stack would be the VA C3. 1. it makes the most of a 40HP pressure box than anything else. best gain horsepower is greater than peak to peak!
