I wear bifocals
new shift kit
275 Bosch Injectors and tools.
As everyone can probable guess by the header I wear bifocals. I’m getting ready to order gauges for my truck. Problem……. which gauges are the easiest to read and what is the most desirable place to mount the gauges. If I use the pillar mount I have to tilt my head back a little to read them. I think the frog eyes in the center of the dash may be a little far away. With this in mind I’m kind of leaning toward the combo gauge from Gino’s, mounted in a single pod on the pillar. I’m not sure I’ll like this gauge but I’m open to suggestions as I’m sure I’m not the only driver in here that wears glasses.
1999, 2500 QC, Driftwood,Auto, Stock, Cab High Shell, Tow Package, Camper Package.
Gohon,
Check out the SPA Gauges at www.performancediesel. 20m.com. These are the gauges I am going to get. They have digital readouts and are back lit. Very easy to read. Check them out!
99 Quad cab, 4x4, 5-sp, 3:54's, LSD, Valentine One, Tow package, Stainless Nerf Bars, Stainless Rocker plates, Pro-flap mud flaps, Rhino liner, Raven Cap (cab high), Power Edge
I don't wear my bifocals while driving, and don't have any problem reading my gauges on my dual pillar mount.
"Roadrunner"-96 4X4 club cab-12v-auto-3. 54 gears-Amsoil bypass filter - all Amsoil fluids-trans filter-britebox-shelfit-DeeZee boards-Rhino liner-Rancho 5 speed shocks-Hellwig rear antisway & overload springs-Warn 12000 lb. winch-dual redtop optimas-combo gauge and trans. temp gauge in pillar mount-255/85R16 Kelly MSR tires-custom pinstriping- Walker muffler-Cummins mudflaps-Tuff Country control arms-2" coil spacers
I wear trifocals and am nearly blind in one eye and have no problem with the pillar mount gauges. It's the traffic I don't see!!! It's hell getting old!!!
Bill
Y2K 3500QC, 6 Speed, 4. 10, SLT+, Camper & Tow Pkg. , Westin Chrome Nerf Bars, Mopar Flaps, Reese 20K Hitch, V-A CPC, EGT & Boost Gauges, RPM 45 Gallon Aux. Fuel Tank, Highway Products 5th Wheel Toolbox, ECM Controlled PacBrake, Painless Wiring Kit, Mag-Hytec Diff. Cover, 80% Towing Hitchhiker II 31', 2 slideouts, 19,750 GCW
[This message has been edited by Bill Stockard (edited 06-22-2000). ]
BS--damn don't you know it--Shoulda listened to my old man back when I was 13. :rolleyes
2001 QC Dually SLT+ 354 LSD AUTO 4WD Driftwood SS Railcaps Stainless Werks step-rail nerfs Rhino spray-in liner Aux B/U lites Diamond Plate Alum Highways tow box SS Fender lips Jardine 4" Mag-Hytec diff & transmission Alcoa classics Reese 20K hitch 28ft Holiday Rambler 5er w/slide 84 Scrambler 4" lift 33/12. 50's 4. 56 gears soft locker/trac-lok Built 258 w/Mopar fuel injection conversion BUILDING 66-442 Olds, ground up--OH BABY! NRA 25 YEAR MEMBER
