We already have a "fuel heater" to prevent "fuel waxing" during cold winter operation, it comes on below 45 deg. F and is off above 79 deg. F. +/- 8 deg. F. So if you tried to cool the fuel in the summer with ambient air, you might knock several deg. off the temp. depending on how much fuel is in the tank. The fuel in tank should be higher as the level gets lower because some of the fuel is recirculated and you would have less of a "heat sink " of fuel to work with . I think that is why you have approx. 7 gallons of fuel left in tank when the low fuel alarm goes off. If you could figure some way to maintain the fuel at a constant temp. throughout the tank fill to empty cycle you might gain some consistency of engine operation. I don't know if the fuel temp. is a factor as far as life expectancy of the VP, it has to generate lots of heat to produce the pressures it does, of course if you run the tank to near the completely empty stage there is not much fuel left in the tank for a heat sink and the fuel temp. of fuel being returned to the VP has to get higher. bg
