Any one have an explanation as to WHY the central axle dissconnect sometimes does not work in the cold????
Mine seems to fail below 20 or so. . I chased the VAC signal to the disc shaped actuator on the axle where the vac lines connect..... good suction. Still no 4wd..... ? Next, I took a heat gun to the disc shaped actuator and warmed it up good, 4wd works perfect... .
I have read so much about the fact that this system is known to fail in the cold (when it's most needed) but never any explanation as to what causes the failure.
I plan on installing the posi lock cable but would rather not shell out the $$$ right this minute if I can find a way to make this crippled ship sail a little while longer.
Cold Snowy rocky mountains, winter will be here till june, 2wd diesel truck not good!!!!!!!
