ID housing, How???
Cost to Set Timing?
free muffler
Just wanting to know how to identifey what turbo housing I have on my truck. Dose eney body now how I can check this out by numbers or some how. See sig for year, I just dont want to buy one if i already have a smaller one on it, you never know???
Thanks Justin:eek:
It's labelled in raised lettering on the back side of the housing. It should just be the numbers like "18" or something like that. You may need a small mirror to see it.
Mike
Justin,
The 92 trucks came with the 21 cm housing. I pulled my old one of the shelf and and as Mike says you will need a mirror to see the number. The number is just below where the downpipe hooks up to the turbo, you should be able to see the number 21.
Al
I got an exhaust housing from a friend off of a 95 and the Id no. was on the inside. It had no way to tell from the ouside. I got a banks on my truck and have no Idea what size it is. It was on the truck when I bought it.
The first gen stock turbo housings are as follows:
89-91. 5 had 18. 5 housings WH1 turbo
91. 5-92 had 21 housings WH1 turbo
93 went back to the 18. 5 WH1 turbo
