Thanks Daniel,
the injectors showed up yesterday. . there are no external part#s at all on the body or tips. . Don't even have "bosch" stamped on them. . They do have 5 holes in the tips. . the tip shape&spray pattern/angle seems to be a lot like the stock 6 holers...
Is there any way to dissassemble them and find a part# without messing up the pop-off adjustments?
I found this info in the archives... .
The injector #0432133875 is a Bosch #.
The Cummins injector assembly # is 3919744.
The Cummins nozzle# is 3919745, the Bosch nozzle # is 0433175040.
Opening pressure is 245/253 Bar.
The sealing washer is #3906659.
It's a 7mm tip, used on 6 cyl B engines, CPL#856.
