Ideal pressure for Cooper ATP tires?
Feels like it's hitting on 3 at idle
May be time for Shocks. Lift Kit?
I'm sure Cooper ATP are no different than any other tire as far as air pressure is concerned. Go with the recommended pressure in the owners guide and on the sticker on the drivers side door jamb.
In my experience, 80psi in the rear on an empty truck will get me a bad ride, reduced traction and tires gone prematurely bald in the center. Ideal pressures will vary from one tire model to another. What worked best for my BFG Rugged Trails was not so good for BFG A/T KO.
Do a search for TRA load tables and set ptessure based on tire load. I'm traveling at the moment but if you haven't found it by the weekend send me a PM and I'll look it up for you.
I usually set load pressure +5-10psi. That way i dont need to be concerned with outside temp changes putting me at too low of pressure.
